drag suspension guys
hey guys just wandering if any of you have tried preloading your sway bar. i have had a problem with the way my sway bar hangs ever since i made my lower control arms into traction bars. it hung real low and recently the bolts came loose causing a clunk. since i like fabrication, when i was repairing this problem i got to thinkin. so heres what i did, if your looking at the car from the rear i made about a 1 1/4 inch drop bracket for the passenger side front bolt, took that bolt and left the rest in, used a pole jack on the right rear of the sway bar and installed the bracket. this preloads the sway bar to stop the noticable body roll from a launch. as i havent been to the track in a while, when i would floor it first gear at about the middle of the rpm range, the tires wouldnt spin but it would almost feel like my driver front tire would come off the ground (i know it wasnt but still) after i installed the bracket there is noticably less body roll when i do this, the car stays alot flatter and seems to grip harder. just sharing a little tip, use it as you may.
RE: drag suspension guys
bad cell phone pics i just took out in the drive way so bear withme
first of the drop bracket
second is how the sway bar should sit, a little higher on the right side.
http://i302.photobucket.com/albums/n...04369853_0.jpg
http://i302.photobucket.com/albums/n...04369229_0.jpg
ORIGINAL: livefast1
i was bored and had some quarter inch steel layin around and it workd pretty good, it was free and it really worked well.
yea true i had a buddy with an 04 gto that installed 2 of them in the rear and said it made a world of difference, i know its irs which is a whole nother animal (wheel hop= destruction) but i know its the preffered method.
