DiabloSport Predetor
Old 07-16-2008, 07:40 PM
03FASTGT
03FASTGT's Avatar
Default DiabloSport Predetor
Just installed it and it did not ask me what octane level I was running or wanted for the tune. It just said ``installed performance tune``.
Im running 89 Octane
03FASTGT is offline
Old 07-16-2008, 07:59 PM
defconfire
defconfire's Avatar
Default RE: DiabloSport Predetor
I think it gives you a standard 93 tune. but if you dont have detonation/pinging/ticking than awesome your good
defconfire is offline
Old 07-16-2008, 08:01 PM
black35th
black35th's Avatar
Well where did you order it from? What did you specify when you ordered it?
black35th is offline
Old 07-16-2008, 08:42 PM
03FASTGT
03FASTGT's Avatar
I bought it from a local performance shop and I asekd him if it had different levels, he said yes... Hmmm
03FASTGT is offline
Old 07-16-2008, 10:56 PM
ying.yang.gt
ying.yang.gt's Avatar
You can modify the tune if your running lower than 93oct. You can mod the timing if you're getting any pinging. I 89oct an have no issues with the default tune.
ying.yang.gt is offline
Old 07-17-2008, 04:33 PM
20GT02
20GT02's Avatar
http://www.diablosport.com/index.php...lay&pid=55
The Predator comes with only one tune which is the performance 93 octane tune. If you check out the forums on diablo's page, you can get a "how-to" on lowering your spark timing in order to compensate for running lower octane levels. They do however advise that if you are running their unmodified performance tune, 93 octane is REQUIRED due to the fact that detonation is very likely in cars running less than this. Also, what kinda plugs are you running? Id recommend taking out thos factory POS platinums and running a set of Ford Motorcraft AGSF-22c (new part number: SP-505) The copper plugs are better conductors and these are one heat range colder than factory specs and should give you better results when modifying the fuel trim and spark timing.
20GT02 is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
dubarado
12-23-2015 01:16 PM
t3000
05-10-2005 09:03 PM
GT1999
14
12-02-2004 02:10 AM
Diablosport
11-12-2004 11:26 AM
Quick Reply: DiabloSport Predetor
