TRICK FLOW NEW 2V & 4V MODULAR FORD PARTS
TRICK FLOW NEW 2V & 4V MODULAR FORD PARTS[/b]
TFS-51800500 complete timing kit[/b]
Fits 1996-2004 SOHC 2V Romeo or Windsor(with aftermarket cams), comes with everything in the picture.
Includes (2) crank sprockets (1) thick crank gear to be used with the Romeo thin crank trigger wheel, and (1) thin crank gear to be used with the Windsor hub style crank trigger wheel.
Also includes our patent pending Hex cam gears spacers, to make tightening the cam gear bolt easier, without smashing your knuckles on the shock towers on a new edge.
TFS-21400008 New OE 2V & 4V hyd, lash adjusters [/b]
TFS-51800510 New OE 2V & 4V followers [/b]
[/b]
TFS-51800502 Cam Gears and spacers only [/b]
[/b]
TFS-51800501 New 4.6L timing chains, [/b]A MUST FOR KEEPING CAMS IN TIME, WORN OR STRETCHED CHAINS MOVE THE CAMSHAFT CENTERLINE.
[/b]
TFS-51800504 New 5.4L timing chains[/b]
[/b]
TFS-51800503 PAIR OF HEX CAM GEAR SPACERS[/b]
TFS-51800922 OE PI Intake gaskets [/b]
[/b]
[/b]
TFS FMOD valve covers are manufactured from a light weight aluminum casting. Unique design features baffled PCV connection, Baffled and threaded fresh air connection (popular on forced induction cars), OE style seal/gaskets, bolts, bolt seals, and (2) high quality chrome fill caps (does not matter if your car has a left or right side oil fill, these will fit all applications). Made in USA, available late 2008
TFS-51800801[/b]
ROMEO FMOD VALVE COVER SILVER 11 bolt
TFS-51811801[/b]
ROMEO FMOD VALVE COVER BLACK 11 bolt
TFS-5180B1801[/b]
ROMEO FMOD VALVE COVER BARE 11 bolt
TFS-51800802[/b]
WINDSOR/ FMOD VALVE COVER SILVER 13/14 bolt
TFS-51811802[/b]
WINDSOR FMOD VALVE COVER BLACK 13/14 bolt
TFS-5180B802[/b]
WINDSOR FMOD VALVE COVER BARE 13/14 bolt
TFS-K51824070 70MM THROTTLE BODY AND PLENUM COMBO [/b]
TFS-K51824075 75MM THROTTLE BODY AND PLENUM COMBO[/b]
[/b]
[/b]
Be sure to call in and request our 2009 Trick Flow for more up and coming Modular parts.
[/b]
[/b]
[/b]
[/b]
[/b]
[/b]
[/b]
TFS-51800801[/b]
TFS-51811801[/b]
TFS-5180B1801[/b]
TFS-51800802[/b]
TFS-51811802[/b]
TFS-5180B802[/b]
[/b]
[/b]
[/b]
NorthAmericanTuning
11-09-2016 11:44 AM
