fuel pump relay
fuel pump relay
where is the fuel pump relay located at on a 2000 mustang GT? im getting a crank, no start condition and i have spark but no fuel pressure at all. i checked the fuel pump fuse and it is good and bench tested the fuel pump and it is good. checked the inertia switch too and it is good.cant locate the fuel pump relay though. the wiring diagrams i have say it is located under the coolant overflow tank but i cant find anything there.
RE: fuel pump relay
the fuel pump relay is part of ccrm(constant control relay module) which houses other relays as well. it is located on the passenger side behind the splash guard. you would have to replace the entire ccrm unit.
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
