WHat can i expect to hit at the 1/8
Im going this saturday to Irwindale 1/8 mile. I've never been to an 1/8 so im wondering what do you guys think my car should be hitting. I been to a 1/4 about a yr ago when i was stock. My best was a 15.7. NOw my mods are:
Mods are:
Engine: 281 ci
10.1 compression pistons
Manley H-Beam rods
Forged 4340 Crankshaft
Re-machined and balanced at a local shop
Pi heads
Pi intake
Comp Cams xe262ah
cnl plenum
75mm Throttle Body (Professional Products worst company ever, i had to customize to make it fit)
cnl cold air + 80mm maf w/ 9" filter
24lb injectors
Steeda timing aadjuster set at 16 degrees
Tranny:
Stock AODE w/ transgo shift kit
Rear End:
FRPP 3.73 gears w/frrp rear end cover
Exhaust:
BBK shorty
Prochamber mid-pipe
Mac 2.5" catback w/3" tips
Suspension: none yet
Mods are:
Engine: 281 ci
Manley H-Beam rods
Pi heads
Pi intake
Comp Cams xe262ah
cnl plenum
24lb injectors
Tranny:
Rear End:
Exhaust:
BBK shorty
Prochamber mid-pipe
RE: WHat can i expect to hit at the 1/8
Where are you located at? Things like track conditions and altitude can make a big difference.You should be able to run low 8's no problem with some decent tires. My auto'03 GT with x-pipe, 4.10's, canned tune, and LCA's ran 8.5's on crappy Khumo tires.
No i dont have a programmer but im leaning into buying the sct. But maybe i should just wait for a dyno tune. I live in Los Angeles and the weather is not that great. its very humid and hot right now.
Price was a factor and b-cuz i was told that i-beams withstand a lot more power. Im not looking for more than 400rwhp so that was a factor. I'm not pushing it to the limit. STtcking to that hp and hopefully hit 10s with a fully gutted car and high stall + gears.
treesloth
09-28-2015 07:03 AM
