brake problem!!
Hey guys my abs light is on my act can't find the code... But anyways today noticed when I pressed my breaks a weird noise came from it like scaping air or something any thoughts? Thanks!!
From: Where gunshots are more common than birds chirping
A few things that might be worth checking:
- brake fluid level
- are you running two very different size tires front and back?
- connections to the ABS module and CCRM and secure and not interrupted
- brake fluid level
I've got the same basic thing going on myself. I just don't get any noise. It is intermittent. I started getting mine after I changed my diff fluid. I don't know what the connection is between them. It also won't stay on long enough to run an ABS scanner on. It comes on for about 10 minutes and then goes out. I know my fluid is good. I gotta check the other items listed by 35thAnni99GT.
mungodrums
Oct 7, 2015 04:01 AM
musnicki
Sep 23, 2015 07:11 AM
