Engine Build: Oil Pump??
Old Sep 9, 2008 | 12:55 PM
Stevecooper's Avatar
Stevecooper
Originally Posted by Daveo2k6
My stock block
Standard output GT pump will be fine.
Old Sep 9, 2008 | 04:27 PM
myslow2002gt's Avatar
myslow2002gt
Why make sure its billet?
The stock gerotor gears in the pump housing are rather weak and tend to break with increased NVH. If you run a quality harmonic dampener, you'll be ok to ~6500rpm.
If not, there are only two choices I recommend. Either a Melling oil pump or Triangle Speed Shop billet gears. Either way, the standard GT pump pressure is all you need.
djbigskrilla
Sep 20, 2022 01:04 AM
Design1795
Jan 24, 2017 10:38 PM
motown girl
Aug 28, 2015 08:21 AM
Design1795
Aug 24, 2015 04:41 PM
drumhedd2005
Aug 13, 2015 09:59 AM
