Rack & Pinion replacement
Old May 19, 2010 | 08:35 PM
Sniper6677's Avatar
Sniper6677
sqeaking or clunking or creaking? if its a SQEAK i had the same kind of noise...it was coming from the steering column itself....simple lube job fixed that....i would try to verify the exact location of the noise before you throw a hundred some bucks + an alignment (unless you mark the tie rods) + labor
Old May 19, 2010 | 09:12 PM
MidNightRunner's Avatar
MidNightRunner
Originally Posted by brettjr2005
Did this work? I also have a 99 mustang gt with the same issue. I would prefer to buy the tube brackets but the ones listed on the site are for 02-04. I couldn't find the part anywhere, couldn't even find the 02-04 ones without the part number listed in the fix it article. So if anyone knows where I could find the tube brackets for a 99 I would really appreciate it.
I just picked up new ones from a buddy that works at ford... I recommend everyone get one!
Part number: E5DZ 3K620 A
Old May 20, 2010 | 06:16 PM
brettjr2005's Avatar
brettjr2005
It's definitely coming from the rack and pinion, and it sounds similar to an old door hinge making a squeaking/creaking noise. I must admit I'm a bit confused though. Why would it cost hundreds of dollars to do? It seems like everyone was saying it can either be done for free by cutting them down or for not much more just by replacing them.
mtgldr
Feb 3, 2024 09:00 PM
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
MusicCity615
Sep 12, 2015 07:05 AM
Blk Vert
Sep 9, 2015 12:16 PM
