porting EO plenum
Old May 20, 2005 | 12:03 PM
stang869846's Avatar
stang869846
Default RE: porting EO plenum
how exactly do u port the intake plenum and would it be worth it to port the stock throttle body too, j/w
Old May 20, 2005 | 01:30 PM
Monch's Avatar
Monch
i wouldn't bother with the stock tb, a 70mm unit would be the way to go. a while back one of the members here, mdvaldosta, put up a description and pictures of what he did. i pretty much did the same thing, except i didn't bother with the outside of the unit. its pretty easy, but will take you about 3-4 hours because you'll want to go slowly. basically, you want to smooth it out and remove the casting ridges which cause turbulence and decrease flow. course, you should be somewhat skilled at using a dremel or similar rotary tool.
Old May 20, 2005 | 09:47 PM
|MusTang's Avatar
|MusTang
i just baught a 70mm bbk Tb so...
and to port my stock plenum will cost me almost nothing.so if i can gais a little for almost free,i will try it i think
Old May 20, 2005 | 10:45 PM
firemedix911's Avatar
firemedix911
Ok let me say something here. I installed a 75 mm TB & plenum combo from accufab. It made a heck of a diference in my car. Have no experience with porting the stock plenum so I couldn't tell you if there is any diff. I could tell you this the $400 I spent was woth it. I'm also putting a blower so that's the real reason behind me going that route so I just give u my expirience and you make your decision.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
TfcCDR
Sep 14, 2015 12:08 PM
