Installing a 2 step rev limiter
Ok I found it right before you posted where it was....now I just have to figure out how to get into that dinky area and splice it without a sodering gun. As you can probably tell i've never really dealt with wiring
Sorry I haven't gotten any pics up yet. I ended up taking the 2 step out for now. The quick splice didn't work. I went over that website we had discussed and realized how they had done it. They used the wiring harness from a donor car and plugged it into the clutch switch (since there are 2 spots to plug into) Now I am just waiting to find a donor car that I can get the harness from. Unfortunately I checked all the junk yards in my area and nobody has a 99-04 mustang (much less one that's stick shift). Once I can get that all hooked up I will post up some pictures.
A two-step rev limiter can be programmed into the EEC-V PCM using one of the more "hardcore" tuning applications--I use Sniper's Commando.
Here are the scalar values that need to be set...
TfcCDR
09-14-2015 12:08 PM
