98 GT ORANGE TOP INJECTORS ? LB
Old Sep 26, 2008 | 10:27 AM
98SN95's Avatar
98SN95
Default 98 GT ORANGE TOP INJECTORS ? LB
what are the factory 98 gt injectors rated at? the plug part is orange
Old Sep 26, 2008 | 10:35 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
19 lbs/hr
Old Sep 26, 2008 | 10:51 AM
JTanew's Avatar
JTanew
the orange top in common on 2v 4.6,it is a Bosch 19lbs unit. the blue one is the next highest it is typically used on 93-98 4v engines it is a 24lb Nippondenso unit. the next one is a red bosch 30lb unit. the next one is the skinny eve style injector it is low inertia 03 cobra injector is a dual spray design to produce superior exhaust emissions,it flows 39lbs and is all black w/ lil blue cap. then there is the 42lb lime green top they use on the lightnings its also a Bosch...they even got an after market all black Siemens that flows 83lbs and suppoerts up to 1600 hp.
*injector size* *suppoting HP*
19 *304
24 *384
39 *624
42 *672
these numbers are given @ 45psi fuel pressure.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
Bokeo
Oct 10, 2015 08:28 PM
Dathan
Oct 5, 2015 05:52 AM
