Brake lights not working
Old Oct 4, 2008 | 10:13 AM
GT03 TJS's Avatar
GT03 TJS
Default Brake lights not working
when i step on my brakes, my lights dont work. My reverse lights work, and when i turn on my running lights when it starts getting dark, they work as well...its just the brake lights.
quick fix? do i need a new sensor or something?
Old Oct 4, 2008 | 10:34 AM
blackstallion666's Avatar
blackstallion666
do your turn signals work? If they work then we know the bulbs and wiring to the back is good. then check the brake light switch. Its mounted on the brake pedal itself. make sure its pluged in. if it is disconnect the connector to the switch and jump the pins(wires). if the lights come on then you have a bad switch. also check for bad fuses.
Old Oct 4, 2008 | 11:03 AM
Sxynerd's Avatar
Sxynerd
The switch on the brake may be broken or misaligned. Doughboy4.6 had this issue last summer. It Did the same things you're describing.
Old Oct 4, 2008 | 04:37 PM
GT03 TJS's Avatar
GT03 TJS
thanks for the responses...
just pulled and checked fuse #41....workin fine.... gonna crawl back under in a bit and poke around to see what i can find....
Old Oct 4, 2008 | 04:38 PM
GT03 TJS's Avatar
GT03 TJS
and yeah the turn signals work too....as do the reverse lights and rear running lights...
just nothin when i tap the brakes...
Old Oct 4, 2008 | 07:49 PM
blackstallion666
If you have a meter or test light. with the key on check for power at one of the terminals at the brake light switch. If there power there thats good. now press the brake pedal with the connector installed on the switch and see if you have power on the other side. If thats good. I would say you may have a bad multi function switch (turn signal switch). becuase the wire from the brake switch goes to the multi function switch then to the rear lights. and since your turn signals work that eliminates any damaged wires from the switch to the rear of the car.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
bond007
Aug 26, 2015 11:36 PM
kdryan
Aug 21, 2015 04:01 PM
cody.hoeppner
Aug 12, 2015 06:39 AM
cody.hoeppner
Aug 11, 2015 08:08 PM
