181 Fuel Temperature Sensor A Circuit
#34
BlackStallion,
Have you seen my fix for Recon? It corrects the long and short term fuel trim display.
I have also updated the SFScrape Special Forces tune documenter so that the captions for the PT and FT fuel modifiers correctly identify the effect of selecting values above or below 1.0 (it is incorrect in the SF manual, and the captions were inappropriate for the selections offered).
#35
The OL/CL thing bugs me too, I know what the problem is but without access to the Sniper source code I can't fix it.
Just set you mind to Red = Closed (which is BAD 'cause the PCM is calling the shots), Green = Open (GOOD because your settings are in control)...
Also, I have been playing in Commando with making OL happen sooner and more often. It increases power but can kill fuel economy, there's got to be a balance there though...
#36
#38
Good news, changing the fuel filter fixed the 181 code and it hasn't popped back up since.
I took out the catted H-pipe (looked like an aftermarket high flow) and put in an OR X-pipe.
As soon as I pulled out the old H-pipe I heard something rattling around inside of it and white junk fell out. Anyway, she sounds like a mustang now and runs like one too. Thanks Cliffyk and blackstallion for your help.
TfcCDR
09-14-2015 12:08 PM
