hi flow cats
O/R pipes are cheap, compared to High Flows. Although if you plan to get Long Tubes in the near future, you need to select the right type of Mid Pipe to accompany them (In most cases).
It is still a federal offense to remove those cats, doesn't matter what state. Chances that you get caught for that are slim but you will get effed in the a if you do.
You've never removed cats before have you? Removing the cats is what makes it loud as hell, regardless of pipe diameter. Also, longtubes DO NOT make your car louder!! If you think it does then you've obiviously never had them. The cat-back affects volume as does the cats. The cats affect the actual volume more than anything. Trust me, I've had two GTs, two Machs, a GTO, and a Z28. They all were experimented on.
Correct..
In answer to your question, yes I have removed Cats (Goes with the territory of being an Apprenticing Mechanic.. I like to play around and see what's what.)
As my Sig states, I'm currently running HF Cats, and I also have run without any cats.
The sound difference between no cats on my NPI and High Flows has been too close to call, really. For the possibility of an impending ticket for No Cats, High Flows are the way to go.
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
09-10-2015 08:39 PM
