STILL WON'T START
Old 10-25-2008, 01:35 PM
97modifiedmustangGT
97modifiedmustangGT's Avatar
Default STILL WON'T START
Well I don't know if anyone will remember but about a week ago i had a thread about how it is the first start after my head swap and it won't start. Today i pulled the timing cover off because while trying to start i had a very small intake tube backfire so people suggested timing. come to find out timing is dead on. I bought new tensioners because i thought mine were bad so i will be resetting timing anyway with the new tensioners. where do i look now??
97modifiedmustangGT is offline
Old 10-25-2008, 02:18 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Hm...
I dont remember if you covered this before but do you have fuel pressure? Injector pulse? And did you swap to COPs or do you still have the 2 coils with wires? Do you have spark? Also, when you are cranking it, does the THEFT light flash
WhiteFoxGT is offline
Old 10-25-2008, 02:33 PM
SNOW
SNOW's Avatar
Have the cams been off the heads? I'm not sure but I think the cams are different from right side cam and left side cam.
SNOW is offline
Old 10-25-2008, 05:03 PM
97modifiedmustangGT
the cams were put on the right head, because you are right, it matters what side they go on. i have fuel pressure, i am still running coil packs, didn't look at the theft light but am pretty sure it was solid while cranking, i've got spark, the only thing i'm not sure on is the injector pulse. what is that light called that checks that? i can't think of it off the top of my head
Old 10-25-2008, 08:47 PM
97modifiedmustangGT
car is ready to start for tomorrow. so i will let you know if i have the same problems.
And might i say, valve covers are a B to put on while the motor is in the car lol.
Old 10-26-2008, 06:07 PM
97modifiedmustangGT
well i have strong cranking... but still no start. plenty of fuel, got spark, and theft light is solid. i have had a few very small sputter starts but then nothing after. i'm confused
Old 10-26-2008, 09:37 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Is the MAF calibrated to the injectors? Theres nothing in the way of the intake tube correct? Also, if you have cats, they could be clogged. Try unbolting the h-pipe from the headers an inch or two and see if it'll breathe. It almost sounds like the engine isnt breathing.
Old 10-26-2008, 11:05 PM
blackstallion666
blackstallion666's Avatar
have you tried taking the serpantine belt off. Sometimes the alt will put out a freq. that affects the crank and cam signal to the pcm and cuase the car not to start. give that a shot and see what happens.
blackstallion666 is offline
Old 10-27-2008, 09:38 AM
97modifiedmustangGT
stock MAF, stock injectors, no cats. yeah i read about the alternator thing in another post and it won't start with the belt on or off.
Old 10-27-2008, 10:00 AM
ashtondiff
ashtondiff's Avatar
something binding in the motor? too tight?
ashtondiff is offline
Quick Reply: STILL WON'T START
