MSD Ignition??
Old May 25, 2005 | 05:42 AM
andy98gt's Avatar
andy98gt
Default MSD Ignition??
Could someone properly explain to me what MSD ignition is and how it could help your car?? I just dont have a clue about MSD
Thanx
Old May 25, 2005 | 06:06 AM
sq2drsq's Avatar
sq2drsq
Default RE: MSD Ignition??
I am not exactly a genius when it comes to the 4.6 mod motor, but I would have to assume it would do the same as for the old 5.0. Increase ignition (spark) voltage which would help in high compression motors. I.E. to keep the spark from being "blown out" on a n/a motor it would do the same, but help the ignition(D.I.S. on the mod motors) have less spark "fall off" at high RPM. It may also help low end power production with a hotter spark from the plug at low RPM (fifth on the highway and wanting to pass that slow *** semi without changing gears) by bridging the flame kernel with a lil more juice. I put one on my ol' 5.0 and it was a significant gain in feel and driveability, as well as miles to the gallon. But my 306 stroker with a Kenne-Bell was a totally different animal than what we are talking about.
Old May 25, 2005 | 06:14 AM
andy98gt's Avatar
andy98gt
So should i get some MSD ignition stuff for my car w/ all the mods i have?? Would it be a good investment? Cause after my swap my compression will be 10:1
Old May 25, 2005 | 06:25 AM
sq2drsq's Avatar
sq2drsq
If you have the money to do so I would say............mmmmmmmmmmmmm maybe. depends on what future plans for the car are. If you have major modifications coming then yeah. If you are going to stay with N/A and a few bolt on's then the stock ignition should do just fine. Maybe some better plugs and wires. Denso Iridiums are the s**t and nothing less than Bosch 8.2 mm if you can find them at your local parts house.
bradleyb
Nov 27, 2015 07:50 PM
firehorse02
Nov 16, 2015 11:28 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
jessicarabbit
Sep 25, 2015 12:41 PM
Wombatnation
Sep 13, 2015 09:16 PM
