springs??
springs??
I was looking into springs for my 97 Cobra and was wandering which to get?? How much to drop it without messing crap up underneath, up front, and the wells? How s you know if you need c/c plates?? Any help??
RE: springs??
Well, it’s all about personal preference. Eibach and Steeda are both great kits. (I have the Eibachs and can’t comment on the Steeda’s, but hear that they are every bit as good as the ‘Bachs.) The Eibach Pro Kit will give you a modest 1 ¼ to 1 ½ inch drop and NOT require new C/C plates. The Sportlines will take you down to 2 inches, and it’s said that anything over 1 ½ inches requires new Camber/Caster plates (or you’ll wear down your tires).
I wanted a good drop too, but nothing too drastic. I went with the Eibach Pro Kit. It’s not slammed, but noticeably lower. The install is very easy too – took me about a ½ hour for each spring.
Hope this helps and good luck! [8D]
RE: springs??
ORIGINAL: 97 CobraCoupe
Can you do the install yourself or is it cheaper to get it done with the risk of getting hurt? Also, how much do they cost for the kit you got and where did you get it?
I got my Eibach’s here for less than $230 shipped FYI------> http://optionimports.com/3510-14a.html
If you have a floor jack, jack stands and socket set, you have all required materials to do your springs (NO SPRING COMPRESSORS NEEDED). PM me if you have Q's.....
RE: springs??
arent there like tools u need to compress the springs or just something i dont know. i just paid someone dont really have the time and money to make a stupid mistake and hurt my car. paid $200 for it to be done.
RE: springs??
ORIGINAL: DuckyGt
Here is what the BBK progressive rate springs look like on my '03 GT. Believe it or not, that's only a 1.5" drop in the front and 0.8" in the rear (click on the pic for a closer look). I used to have H&R fixed rate 1.5" all around but I changed it up to these - make sure you get PROGRESSIVE rate springs
[IMG]local://upfiles/6591/74C2B72A9D854757BAE981C33BF6B773.jpg[/IMG]
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
