can it be fixed right?
gotta 00' gt bout 3 wks ago, it's been lowered! i think way too much, or a cheap way? if i ever have a passenger (front or back) and i hit any kind of deviation in the road it feels like my *** end and tires is going to come up thru the floor! what'ta think i could do to correct this? its got 18'' saleens on it w/ low, low way to low profile tires on it! gettin new tires though. thanks for any advice!!
A taller tire would help a lot. The stock 245/45-17 has a 12.84 inch radius. I'm assuming that you have 18x9 wheels. A lot of people replace the stock wheels with a 265/35-18 tire which has a 12.65 inch radius because it will not change your speedometer very much.. If you replaced the tires with a 275/45-18 has a 13.87 radius. This tire will raise your car about an inch or more but you will have to re-calibrate your speedometer.
It will also give you a higher effective gear ratio by about 8% (749.8 revolutions per mile instead of 809.9).
You can use the tire calculator to check other tire sizes.
http://www.1010tires.com/TireSizeCal...?action=submit
I'd get a good set of lowering springs that are more conservative. I definately wouldn't put stock springs back in because that height doesn't look good. Having those tires would definately hurt ride quality too like eagle2000gt said above.
bradleyb
11-27-2015 07:50 PM
