Vortech intercooling question
I plan on buying a V3 kit sometime in the future and have some questions about intercooling a vortech setup. First, am I better off going with Vortech's water-cooling aftercooler setup or should I just buy an air-air intercooler and have whatever piping fabricated that I would need? Second, if the vortech setup is going to be better, will the fluidyne heat exchanger for the termis fit our cars as an upgrade to the vortech exchanger?
Some people complain about vortech's aftercooling system because of heat soak when used excessively. It is up to you I think they look real clean I would go with their's. If you make your own air to air it is way cheaper and practically no heat soak problems.
That really depends on what you're doing with the car. I have a Vortech setup with an air-air intercooler and I'm very happy with it. I also wouldn't pay someone to do it if I was you. It's really not that bad... just start measuring and cutting and it should be no big deal.
If vortech is the best setup with an air to air intercooler, I have no problem learning some fabrication. But for power, how do they compare to the other blower setups? The procharger kits are pretty much exactly what I'm looking for, but I've heard people going either way on how they perform on our cars.
You really shouldn't see significantly higher numbers with either supercharger, it just comes down to preference and price.
The V3 is a self contained setup, but so are the prochargers. The difference would be that when I decide to upgrade, all of the prochargers are self contained, I believe. But the difference now would be building a intercooler setup for a V3 or getting the procharger that has the exact intercooler setup I would like.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
