procharger help
Old Feb 7, 2009 | 02:10 AM
timc's Avatar
timc
yah i was planning on do the same thing with the pi heads, and manifold , i have a pulley that can run 10 psi , but that is going to have to wait , until i can get different rods and lower compression pistons, and some super charger cams ,
but that will be next year , i just want run the 8 psi for now , did you end up using the fmu? and what size injectors are you using, thanks im sure i will have some more tech question for you if you dont mind?
tim
Old Feb 7, 2009 | 04:25 PM
Obsequious1's Avatar
Obsequious1
I CAN E-MAIL YOU THE 99/04 MANUAL IF YOU STILL WANT IT. YOU'LL PROBABLY HAVE TO GET THE BRACKET AND THE RIGHT PULLEY SPACERS.
PM ME ABOUT THE MANUAL OR YOU CAN VIEW IT HERE..http://s214.photobucket.com/albums/c...rger%20Manual/
Old Feb 8, 2009 | 02:40 AM
timc's Avatar
timc
thanks i already have that manunal i need the one for a 98 , but thank you very much
Old Feb 8, 2009 | 09:11 AM
Chris98Gt's Avatar
Chris98Gt
I think the bracket assembly comes with the correct idler and spacers. I didn't use a fmu I just used a vortech 98 specifc 255 pump and 42lb injectors.
articman
Jun 21, 2018 11:45 PM
Granatelli Sales
Mar 21, 2016 06:16 PM
Dragonus18
Sep 9, 2015 01:21 AM
Black_GT_02
Aug 20, 2015 01:26 PM
RedStangGT2000
May 15, 2004 05:55 PM
