wierd problem this morning when i turned on my car
+1^ Everything electrical in my car went nuts. Took the battery in and found it was toast. Replaced the battery and everything was fine.
Take jumper cables and attach them to the battery then quickly hit the unconnected ends together (looking for the arc), if no sparks then your battery is bad. Quick and easy way to find out
What does doing that have to do with the condition of the battery... If it has any voltage it should arc. Whether it be 12.5 or 7.5.. I dont see that as bein valid test. Anyway, I still believe the OP has a weak battery and/or dying alternator. Replace battery and start from there.
I wouldn't replace the battery if it isn't dead but that's just me.
I had the same issues he was having and didn't know if it was my battery or alternator. I didn't want to take my alternator out if it wasn't bad. I hooked my cables to my battery and touched the ends together and didn't get any spark. Even though my battery indicator still read green it was dead. It was a quick and easy test to see if my battery was dead.
At least the guy was in his own driveway when it happened to him. Good luck to getting your car on the road again.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
