Idle Problems?
Old Feb 8, 2009 | 12:25 PM
octain01's Avatar
octain01
Default Idle Problems?
Not sure where to start here, but my 2000 GT will idle up to 2,000RPM, then down to 800, then maybe back to 1500. It varies. sometime it will die. anyone know what could cause it to Idle like this?
Old Feb 8, 2009 | 04:44 PM
octain01's Avatar
octain01
Also If i rev it a little, when I let off, it stays reved for a few secs before it starts to idle again..
Old Feb 9, 2009 | 10:41 AM
96GT34's Avatar
96GT34
has it thrown a code?
Old Feb 9, 2009 | 10:53 AM
mustangsam's Avatar
mustangsam
sounds like your IAC (Idle air Control Valve)
Old Feb 10, 2009 | 04:02 PM
octain01's Avatar
octain01
That's what it was, I cleaned it up, runs better. Just a temp fix till I get a new one.
Old Feb 11, 2009 | 04:25 PM
crewwolfy's Avatar
crewwolfy
Here's a question. I had that code, got a new IAC valve, but the problem didn't change. Idles between 1000-1400 RPMs. Am I looking for a vacuum leak at this point? Anywhere in particular I should be looking? I tried spraying soapy water on seams/joints, but never saw any bubbles..
Old Feb 11, 2009 | 07:24 PM
stangdriver2007's Avatar
stangdriver2007
if you have a constant idle at that then you should keep looking for a vaccuum leak. if you still can't find one adjust your idle set screw and see how it runs then. The vaccuum lines you really should be looking at are the ones going to the plenum or the connections at the plenum.
Old Feb 11, 2009 | 09:22 PM
crewwolfy's Avatar
crewwolfy
So start at the plenum and follow the vacuum lines out from there? I'll see what I can turn up. Thanks.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
