do shift kits help??
Old Jun 12, 2005 | 05:27 PM
freeunit's Avatar
freeunit
Default RE: do shift kits help??
will a shift kit lower my quarter mile time???
Old Jun 12, 2005 | 05:44 PM
GreyStang's Avatar
GreyStang
Because it makes the auto tranny shift faster & harder (& at higher rpm?) yea I guess your 1/4 miles times should improve a bit.
Does anyone still make manual valve bodies for late model auto trannies? They were popular years ago, & turned your auto into a semi-auto.
Old Jun 12, 2005 | 06:06 PM
Acer2428's Avatar
Acer2428
Site Mod
Yep
Lentech does.
Old Jun 12, 2005 | 11:00 PM
maddash's Avatar
maddash
I was thinking about a shift kit at one time,but ended getting the predator which can do about the same thing plus it give you noticable horsepower gains at the same time, plus you can change your shift point. It is $400 though, but worth in my mind.
Old Jun 12, 2005 | 11:44 PM
Stang9946's Avatar
Stang9946
ORIGINAL: freeunit
what is the best brand and price range?? Can i install it myself. i installed my intake,TB and plenum myself is it harder than any of that?
I wouldn't suggest installing it yourself. Improper installation will lead to a dead tranny.
Old Jun 13, 2005 | 11:05 AM
DIVER8374's Avatar
DIVER8374
ORIGINAL: maddash
I also have the predator which I used to modify the shift points and pressure. After putting in the shift kit, what the predator did was like nothing compared to the shift kit. I have used the predator to up my shift pressure with the shift kit in and it shifts like a mother!!!! When I ran it down the 1/8 mile it was spinning good from 1-2 and then it was chriping the tires right as I crossed the trap shifting from 2-3. Get a shift kit you will love it!!! I would also suggest that you put a trans cooler on too. I did and my trans runs a lot cooler unless I am sitting in stop and go traffic, but once I get moveing it drops to around 180 Deg. or so and when I run it on the highway it will be down areound 160 or so.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Explosive
Oct 2, 2015 07:45 AM
