Pulling the engine...question.
Old Feb 18, 2009 | 04:53 PM
Davojan59's Avatar
Davojan59
Default Pulling the engine...question.
Hey guys im getting ready to start on my project (forged sb, heads, cams) once my shortblock arrives and i was wondering whats a better way to pull the engine out. Im gonna do it at the hobby shop on base so i will have a lift to use. The thing is that the guy working at the place told me that on these modulars u can only drop the engine after removing the K member, but in the online ford manual it says to lift it out from the top. So how have u guys done this, for those who have? And if u have any other pointers, im all ears! Thanks
Dave
Old Feb 18, 2009 | 06:10 PM
Davojan59's Avatar
Davojan59
bueler...?
Old Feb 18, 2009 | 06:22 PM
ridethemustanggt's Avatar
ridethemustanggt
Most people pull them from the top, it has pretty good clearance. You can drop it from the bottom if you want.
Old Feb 18, 2009 | 06:35 PM
Davojan59's Avatar
Davojan59
oh ok well i guess i was gonna do it from the top if there are no clearance issues. Im looking for the easier way obviously
Old Feb 18, 2009 | 08:26 PM
97gold's Avatar
97gold
i pulled mine out from the top with no problem's
Old Feb 18, 2009 | 09:27 PM
Davojan59's Avatar
Davojan59
awesome, now i want to drop the tranny first, the way my tuner did it before when he installed the clutch, he just took the driveshaft off and put a rubber glove at the back end of the tranny and just put a rubber band over it ot hold it there. Do u think thats a decent way to plug it up in order not to lose any tranny fluid. Or is the fluid on manuals not going to leak out? The reason im asking is cause i tried to do the same thing on my buddy's blazer auto and the fluid started flowing out of it instantly. thanks again
Old Feb 19, 2009 | 08:16 AM
jlg32281's Avatar
jlg32281
If you have a lift, then dropping it from the bottom is much easier. It come out the top without issue, but with a lift, it's definitely easier from the bottom.
Old Feb 19, 2009 | 12:29 PM
amoosenamedhank's Avatar
amoosenamedhank
Because I don't have access to a lift I have always pulled the engine out the top. But I have heard with a lift it's a snap to get it out the bottom.
Old Feb 19, 2009 | 06:28 PM
Davojan59's Avatar
Davojan59
oh ok well ill do that then. The thing im a little confused about is what exactly do i use to lower it? Like do i use a transmission jack to lower it?
Old Feb 19, 2009 | 09:21 PM
mustangman03's Avatar
mustangman03
If its anything like a crown vic pull it out of the top drop the tranny first it only took me about 1 1/2 - 2 hrs to pull one of those.
baddog671
Jul 26, 2016 01:20 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
jrrhd73must
Oct 2, 2015 09:17 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
