help please? wont fire...
Hello,
just installed cams, pypes l/t headers, and pypes o/r h pipe on a 99 4.6, have everything bolted back together, tried starting, wants to turn over but wont... any ideas?
I know its probably something stupid that we've overlooked but ANYTHING would be greatly appreciated!
make sure cam and crank sen are on?? timing set right..those are the big ones..sounds like you might be off on your timing..if it wants to fire but wont and you did cams i bet they are off..alot of work to check but i bet your off a mark..half of a mark the car will run i have done this before..good luck
