Roots vs. Centrifugal!?!?
You will hear all sorts of thoughts about which is best. One school of thought is that centrifical supercharger are better for the track and twin-screws are better for the street. I disagree completely.
Is your car a daily driver? Do you drive it in the winter? Do you drive in snow? Will other people be driving your car?
My car is a daily driver, summer and winter, and my wife sometimes drives my car. For these reasons I chose a centrifical supercharger (ProCharger). Twin-screws provide more low end torque which I've heard can be harder on your motor. Also, the more low end torque you have the more careful you have to be accelerating. With a centrifical supercharger the car drives pretty much like a stock Mustang at low rpm. It easy for my wife to handle and its earier to drive on snow and ice but the power is still there when I want it.
I put on the ProCharger at 80,000 miles. I've driven it about 35,000 miles without any problems. Most tuners will recommend that you not exceed 370-380 rwhp for a daily driver on a stock block.
a centrifugal would be best if you are ocncerned about daily driving/gas mielage, if you dont ocme into boost your car will run and drive liek a stock gt....if you want it to last, then get forged rods and supporting b.s. and then you can safely run a KB with 8-10psi intercooled would be best...
ftw this kit takes care of most of the eaton's problems. http://www.haneymotorsport.com/1999-...ntercooler.htm
hey thanks everyone for your replies eagle 2000 what kind of tranny do you have in your car i have a stupid auto tranny wish i could replace but does anyone kno if i would have to do anything to tranny to beef her up to stand the extra power and yes when im away my mother will borrow my car and its so bad to drive in snow on the nitto 555 i dont even attempt it anymore but it is a daily driver any other time any thoughts
+ 1 on the Procharger. I was really thinking about going with another brand but got a buddy that has 410's and the Procharger works very well the 410's.
If your transmission is in good shape it should be OK without doing anything to it. You don't need a new stall converter because you're not putting in a radical cam. You might want to put in a shift kit and have a tuner adjust your shift points but that isn't absolutely necessary.
If your mother is going to drive your car then I definitely recommend a centrifical supercharger over the twin-screw.
Good decision on not driving in snow with Nitto 555s. Summer high performance tires are the single biggest reason that Mustangs have a bad winter driving reputation. Get a set of ultra high performance all season tires like Continential's Extreme Contact. They make a world of difference.
hey man thinks for all the info I think imma do a gear swap and swap the 2.73's i believe thats what we do have in our automatics right? because i dont want to go to steep of a gear and have my rpms higher on the highway or loose my top end speed, but what gears do you have in ur GT, Ill probably go ahead and put new fluid in the tranny and install a shift kit, but thanks man for ur insight great info, and year imma update my garage just havent gotten around to it
