i need help!!!
i need help!!!
look i need help with this 4.6 its a 99 cobra svt we put it in a 49 pu at work no one had diagrams so we found all the wires one at a time. we have an aftermarket gauge pod.but we dont have the stock housing.you open the old one and install the new one in the old bezel eazy enough.what im getting at is we dont have the wireing harness its just studs sticking out. dose anyone know off hand what stud is what or have a diagram??we called the manufactur but they told us we need an old bezel. i dont want to go in there and start probing around and blow up the cluster! if you could help you would help us from going crazy thanks
RE: i need help!!!
sorry if u actually pull the gauge pod apart the gauges have little metal rods that slide into place u bolt it back together plug the harness in the back.well i have the piece with the metal rods and nothing else there is no room 4 for back side of the pod si i need 2 know witch rod is power ground signal and ignition.
