Vortech 3.33 pulley risk?
Old Jun 17, 2005 | 12:57 AM
  #31
BicketyBam's Avatar
BicketyBam
Default RE: Vortech 3.33 pulley risk?
ORIGINAL: nanaki
i should be able to hit the 370s once i get tb/plenum & headers.
Easily. What are you using for a MAM? Just curious.
Old Jun 17, 2005 | 01:01 AM
  #32
BicketyBam's Avatar
BicketyBam
ORIGINAL: Voodoo
I also found a more experienced tuner near me and talked to him about the 10lb pulley. He said that a 10lb probably would not make any more HP than the 8lb since he would just have to time it down in the higher rpm defeating the purpose. He said he wasn't at all worried about the higher boost with no aftercooler. He did say though that I might see a little more power at a lower RPM. Of course this remains to be seen.
Picking the right person to tune your s/c'd car is the most important part of the equation.
Old Jun 17, 2005 | 09:23 AM
  #33
nanaki's Avatar
nanaki
Retired MF Moderator
ORIGINAL: Voodoo
ORIGINAL: nanaki
What is your set up now?
X, catback, gears, vortech V2 SQ, AFM powerpipe, 42lbs injectors, fuel pump, 85mm maf. i have some other things, but nothing that gives power.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
spdeplayer2
Oct 24, 2015 09:45 AM
jrrhd73must
Oct 2, 2015 09:17 PM
ctgreddy
Sep 20, 2015 08:35 PM
Sep 16, 2015 07:53 PM
