Dome Light Wont Turn off
Ok here's the deal I have a 99 mustang V6 that a V8 was swaped into a few years ago all is well with that. But as of today my dome light will not turn off......car running not running all doors closed.............used keyless entry to lock and light stays on......i have pulled the fuse for now but I need a dome light the vert is very dark with out it.
its the damn door switch... happened in my ranger, i was told if you grease the contact points it will start working again.
btw. my ranger fuse was also the spedo/odo fuse... i drove that effer for 2 years without ever putting a mile on it... my ticket to hell.
^ got it backwards, MAD, the light WONT go out
There is a timer located in the "black box" directly to the side of fuse box on drivers side kick panel. My guess is the timer has an issue, because the light would eventually go out even if you left a door/trunk open.
You may need to go to a dealer for this one.
Jazzer
Jazzer
The windows stopped working in my wifes Honda last summer and we couldn't figure out why. I figured it was some reverse polarity switch that went bad (or something technical). I pulled out the dash (which is a engineering feat all in it's own), took off all the door panels, found $1.78 in change and traced every circuit to every door with my multi meter... then as I'm Face Down *** Up feet to the sky under the dash my wife walks up to the CRV and says, "WHAT"S THIS BUTTON DO?" ''flip! And the windows all start to roll down as she hits the buttons..... There was a window lock button. FUTHER MUCKER!
Humble Pie!
