IDLE PROBLEMS
Old Jun 16, 2005 | 03:42 AM
1997 GT's Avatar
1997 GT
Default IDLE PROBLEMS
I have a 97 gt it idels at 800rpms in gear. I hade a engin code that said heated o2 senser I replaced the o2 senser and removed the + battery cable to reset the computer. now when I put the car in park the cars iddle slows down and stalls. I need help
Old Jun 16, 2005 | 12:07 PM
Deannostang's Avatar
Deannostang
Default RE: IDLE PROBLEMS
Which O2 sensor did your replace? My '98 has four (4) of them. The uppers are different than the lowers. I had to eventually replace all four of mine. You may need "both" uppers or both lowers. The uppers are more common to go bad. Use Ford parts. Many aftermarket manufacturers do not include the pigrtail attachment at the end of the wiring harness. You then have to splice-in the attachments from your old sensors. Not too cool of a thing to have to do. All Ford's sensors have the complete harnesses included as one piece.
Any modification on your engine will take time for the computer to readjust to. If you disconnected your battery while you did the work, you should start to smooth out after about a half tank of gas. Just run it a bit and be sure you don't need another O2 sensor or that you replaced the bad one to begin with.
Old Jun 16, 2005 | 09:12 PM
01roushnj's Avatar
01roushnj
IAC
Old Jun 16, 2005 | 11:16 PM
STANGTVERT's Avatar
STANGTVERT
I ♥ Acer
IAC=IDLE AIR CONTROL (VALVE)
Old Jun 17, 2005 | 12:47 AM
RollinThunder's Avatar
RollinThunder
my mustang has the same problem ...especially when its cold...tonight it almost died out on me...do u think it could b the AIC?...if so how do I clean it?
Old Jun 17, 2005 | 02:53 PM
SilverGTV8's Avatar
SilverGTV8
IAC
You can use carb cleaner, but it may only solve the issue for a little bit.
Old Jun 19, 2005 | 04:17 AM
jishead's Avatar
jishead
Sounds like IAC. If the computer can't open up the IAC and feed adequate air (bypassing your throttle body) into the plenum then your car will idle like 1@#$ especially cold or running A/C etc.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
