H & R Sport Springs installed.
Old Mar 28, 2009 | 10:12 PM
hot wheels's Avatar
hot wheels
Originally Posted by 945LSTANG
stop talking out your ***....no they wont.
springs dont settle much at all.
thinking the same thing.
Old Mar 28, 2009 | 10:21 PM
03svtcobra12's Avatar
03svtcobra12
+1 on springs not "settling" a noticeable amount
Old Mar 28, 2009 | 11:08 PM
mvr's Avatar
mvr
i had these springs on my car, i did not like them at all. defiantly the back was lower than the front. it pissed me off.
right now im running the stock springs with a half a coil cut in back and the sport springs up front. after i install my longtubes i will either buy a new set of springs or take out a front iso and cut some more off the rear.
Old Mar 29, 2009 | 01:44 AM
iMTB's Avatar
iMTB
I have slight reverse rake. I'm taking out the front isos tomorrow because after 3 months my springs haven't "settled" yet...
Old Mar 29, 2009 | 08:28 AM
Timspony's Avatar
Timspony
SVT Section Moderator
I don't think the springs will will settle that much...any pics?
Old Mar 29, 2009 | 06:37 PM
mvr's Avatar
mvr
here they are on my car. two year old springs at that point. my rear shocks were also BLOWN in that picture, i dont think that made a difference because when i put new shocks on it still had a similar stance.
Old Mar 30, 2009 | 05:20 PM
Shelbyville's Avatar
Shelbyville
OK, will for anyone interested, I did call H & R tech support. The answer is the springs WILL NOT settle over time. They are what they are. He told me to make sure the front springs were installed correctly. The pigtail, or end of the spring, on the bottom should line up with a hole on the pocket that holds the spring (drain hole) attached to the lower control arm. He said sometimes just turning the spring 1/4 or 1/2 a turn can make a difference. I checked my car and there are two drain holes on the lower pocket. The installation manual says the spring should cover only one hole, which it does. You obviously want at least one drain hole open. I may take it back to the shop and see if they can turn it a bit to bring it down.
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 30, 2015 12:39 PM
mungodrums
Sep 28, 2015 10:54 PM
