Help putting Headlight knob back on!@
Help putting Headlight **** back on!@
So I took out my gauge cluster to swap with white face gauges in my 1999 Mustang GT.
Now I cant put the headlight **** back on.
I push it back on the pin but it wont stay on when I pull the **** out to turn on Headlights
anyone have a write up??? or know how
How did you take it off?
If you just pulled it off then the internal spring clip may be distorted, and/or the plastic barrel may be cracked--in either case you will likely need a new ****.
The proper procedure for removal is to pull forward on the spring clip, through the hole in the barrel, with a small tool.
It just slides over the pin, but the little metal tab is bent too far.
Hold the switch and take a small screw driver and push metal clip further away from the end of the **** (the end you grasp to turn on the lights). This is a Chinese finger trap type of connection. When you slide the **** into place, you will see the metal clip be flexed further into the **** and how it grasps the triangular pin.
Don't push it very hard as it is hardened metal and will break.
HTH
Jazzer
HTH
Jazzer
I don't know how often the previous owner took my head light **** off but when I took it off the metal clasp had lost all of its tension so I had to buy a new ****. Usually you can bend it back in place so that it will hold. This time I couldn't.
New ***** aren't too expensive but it was a surprise when it came in with the metal shaft attached. To install the new **** with metal shaft you have to take the instrument cluster bezel out, press a down on a button on top of the head light switch to remove the old metal shaft, put the instrument cluster bezel back in, and push in the new ****. It automatically locks in place.
