Lowered my car, now abs light is on.
04-02-2009, 07:31 AM
lowered my car the other day and when i turned it on after i was finished the abs light was on. anyone know why this would be?
04-02-2009, 07:34 AM
You either disconnected or bent the sensor. Easy fix, just go to every sensor and "fiddle" with it till find the problem.
04-02-2009, 09:59 AM
+1 Also check to see if you damaged or discconected the abs wire.
04-02-2009, 11:29 AM
You did something to the wheel speed sensors. That's the only thing that would affect the ABS that you went near while installing springs.
04-02-2009, 01:32 PM
once i "fiddle" with the sensors it should go away? or so i have to replce them
04-02-2009, 02:13 PM
Quote:
Originally Posted by
Blk003GT
...unless you damaged them.
04-02-2009, 04:41 PM
are the sensors in the wheel hub or along the wire? and how can i tell if i dammaged them?
04-02-2009, 08:54 PM
I did the same thing. Mine came on after I did my rear springs after I did a test drive hitting a dump in the road. It when off for a while a couple rides ago then it came back on, so I think I have gotten a loose wire or connection on one side. I just haven't gotten to look under to find out what I did.
Lynn
djbigskrilla
09-20-2022 01:04 AM
inyadreems
08-21-2015 09:10 AM
Soldier GT
12
08-20-2015 09:42 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
