P0456 Error Code (Help)
Old Apr 19, 2009 | 10:56 PM
95redv6stang's Avatar
95redv6stang
Update: So, I finally got around to cleaning my IAC along with changing the gas cap and the CEL is still coming up. Also, The idle seems to have changed a little bit (dropping a little quicker) but still hangs at about 1900 RPM's for a couple seconds. I'm thinking this could ALL (CEL/Idle) could be linked to a vacum leak? Can anyone give me advice on the best way to find leaks? I've heard of using propane or TB cleaner but haven't ever done it.
Thanks, Chris
Old Apr 20, 2009 | 06:59 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
I doubt the gas cap was the culprit of the CEL, Its most likely a cracked line, or faulty purge solenoid.. your goin to have to get the system smoke tested to find the leak. As far as the idle, look into the "IAC mod"...Ive heard it helps with the rolling/hanging idle problems people deal with.
Old Apr 20, 2009 | 10:59 AM
jwog666's Avatar
jwog666
+1 on getting it smoke tested. the evap monitor will detect a leak as small as .020" in diameter, and there is no way you will find that without smoke.
Old Apr 20, 2009 | 08:51 PM
95redv6stang
I have been concidering that route but I hear mixed opinions. Some say it does nothing to help, some say it causes you to fail emissions, etc... Still thinking about it.
Where do I get the kit or get it done? I've never heard of that.
Old Apr 21, 2009 | 08:21 AM
jwog666's Avatar
jwog666
[quote= Where do I get the kit or get it done? I've never heard of that.[/quote]
its a machine. dealers and some aftermarket shops have them. if you want to buy a kit most are $1000.00 or more. i would just pay to have it fixed. save yourself a headache.
Old Apr 21, 2009 | 08:52 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
^^ What he said
You cant basically do it yourself. You have to command the purge solenoid (with a scanner), then clamp off the line, then tap the smoke tester into the little green cap under the hood on the evap solenoid. Its not complicated, but its not a driveway job.
Old Apr 21, 2009 | 07:07 PM
95redv6stang
LOL. Thanks. That's what I needed to know
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
ChampInSD
Oct 2, 2015 04:55 AM
