Cobra running hot!!! What is going on?!
#21
Ive got a new noise now. I took the the pump off that the power steering fluid goes into and now i have everything re-connected and a noise is coming from in the engine compartment down by that pulley. It only makes the noise when i turn the wheel (still now power steering) and when i pump the brakes. Im clueless.
http://www.youtube.com/watch?v=GTd4V2Yy7nk
#24
just fill it up to the full line and turn the wheel from lock to lock, this bleeds the system of air. in extreme cases you will have to rig up a system to pull vacuum on the system but turning it from lock to lock and just driving it after that will almost always get the air out of the system.
#27
sometimes it just takes a while, i wouldn't worry to much about it and just drive the car until the noise goes away, the air will eventually bleed out. make sure when your doing the lock to lock thing you don't hold it on the lock for too long. and make sure your doing this with the cap on.
#28
if the probably really persists you can 1. use a large rubber stopper, drill a hole in it and put a plastic hose barb in it, remove the power steering cap and shove the rubber stopper in where the cap goes. take a vacuum brake bleeder and attach it to the nipple on the rubber stopper. start the car up and let the vacuum bleeder run for about 10 minutes. 2. take it to the ford dealership and let them do this as they have the kit to do it.
#29
#30
Ok i sat out there for 10 minutes turning the wheel from side to side with the car on and the noise is still super loud and showed no signs of going away. The power steering works now but the sound is still just as loud.
