Fuel Pump took a dump
Old Apr 14, 2009 | 05:48 PM
4.698GT's Avatar
4.698GT
Default Fuel Pump took a dump
So I am getting nothing when i try starting the car. just spins and spins and spins. No whine from the gas tank. Checked fueses and they all look good. So I need a fuel pump. Its a 98 GT, so can I use a svt focus pump in it or just a regular walbro 255lph?
Old Apr 14, 2009 | 05:56 PM
lizzyfan's Avatar
lizzyfan
Underboss
Stick with a stocker for your setup/power
https://mustangforums.com/forum/5426292-post8.html
Old Apr 14, 2009 | 06:20 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Well before you go condemning the pump, check for power at the pump connector with the key on (your gonna need 2 people the pump only turns on for th first 5 seconds of KOEO)
Make sure the inertia switch isnt kicked. You should have power coming in and going out (with KOEO for the first 5 seconds)
Old Apr 14, 2009 | 06:58 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Did it work before you swapped your carpet out?
Old Apr 14, 2009 | 08:00 PM
4.698GT's Avatar
4.698GT
I had it running while the new carpet was in. I had my brother turn the key to the on while i stuck my head underneath to listen for the pump and heard nothing. I should have check the inertia switch I will try that when I get home.
Old Apr 14, 2009 | 08:05 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Ok, just because you cant hear the pump, doesnt mean the pump itself is bad... You should always check for power at the pump to make sure the circuits are still good and the inertia is operating
Good luck
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
