x2 ball joints help
Old Apr 21, 2009 | 08:31 PM
jrherald420's Avatar
jrherald420
if your lowered YES!!
Old Apr 21, 2009 | 09:47 PM
PaintballFreak's Avatar
PaintballFreak
What kind of grease do I fill them with??
Old Apr 21, 2009 | 09:50 PM
MustangMan00's Avatar
MustangMan00
Originally Posted by 99BlackPonyGT
lol at tie rod fork tool.... remove cotter pin, loosen castle nut until its half way off, tap with hammer
what did you disconnect the tie rods for anyways? i just put a balljoint in my gfs stang and didnt have to disconnect them
ya well i went the more civil way....it was free anyway
Old Apr 21, 2009 | 10:24 PM
mudvayne1's Avatar
mudvayne1
Just use regular grease man.
Old Apr 22, 2009 | 08:20 AM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
ok, but why did you have to disconnect them to do the ball joint?
Old Apr 22, 2009 | 09:00 AM
Kmelfi11's Avatar
Kmelfi11
wouldnt it make sense to leave in the isos and leave out the spacers? doing that you shoud have a real nice drop in the front end and wont have to worry about the isos.
Old Apr 22, 2009 | 03:13 PM
marcuslee842's Avatar
marcuslee842
OP i'm glad u asked this question because I have a big suspension project coming up, and the X2's and LCA's are the only things I am worried about. I have heard nightmare installation stories about both of them.
Old Apr 22, 2009 | 10:25 PM
dimebag's Avatar
dimebag
so ok, say someone had 4cyl springs in the front, for launching. if you install the x2s, and DONT shim the spring, just leave it as is, wouldnt you be lowering the car, while still getting the full effect of using a full sized(not cut for the drop) 4cyl spring? so basically have a lowered front end, but still have all the travel of the suspension, and all the weight transfer advantages of the "drag" spring your using.... i would think this will work
Old Apr 23, 2009 | 11:22 AM
PaintballFreak
Well the instructions say only to use the shim if you are lowered a certain amount. If you aren't lowered 1.75" they say you don't need to use it and if you aren't lowered like 1.25" it says DO NOT use the shim. The point of x2 ball joints is to bring the roll center of the car back down after lowering (shortening spring length), in the first place. If you switch to x2 ball joints without lowering, you will be moving the roll center of the car further away from the ideal point I would think.
mtgldr
Feb 3, 2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
guitarman376
Oct 11, 2015 01:47 AM
marc954
Sep 29, 2015 11:18 AM
gagemcc
Sep 22, 2015 09:43 AM
