Procharger Venting to Atmosphere
Mine runs just fine with it venting to atmosphere. Are you running the standard ProCharger kit which puts the MAF in the passenger fender well after the intercooler but before the throttle body? I believe the bypass hose is connected before the intercooler.
Do you hear the by pass valve open while just cruising? Only thing I can think of is the valve is not opening.
When I built my buddys car with a procharger he wanted to vent it but I didn't because I didn't want to make a bracket to hold the valve from slapping around. Check and make sure the valve isn't resting on anything stopping it performance.
atmopheric, atmosphere, atomosphere, bypass, loud, make, mustang, p1sc, procharger, run, valve, vent, vented, venting
