quick head question
Old Apr 28, 2009 | 01:30 PM
wickedstallion's Avatar
wickedstallion
Default quick head question
i read in the may issue of MM & FF that jpc is using the 4.6 3 valve block and stroking it to 322 ci , well my question is can i use my 4 valve head with this block and what makes this block different from the 2 and 4 valve blocks? also has anyone tried this combo before . thanks
Old Apr 28, 2009 | 02:43 PM
mustangman281's Avatar
mustangman281
Banned
People have been doing it for years with modular blocks (all the same). They are called big bore. Alot of times they leak coolant from around the sleeves which is why ford racing came out with a factory big bore block.
Old Apr 28, 2009 | 03:12 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Just get a stroker kit for your existing block and build off that.
Old Apr 28, 2009 | 04:21 PM
grogan's Avatar
grogan
the difference between the 2vs and 4vs besides inside the heads is the timing chain plate.
and jpc doesnt build the motor, rich grot does. jpc does the work to my car that i cant handle, there sending my block out once i get around to giving them 9k for it.
Old Apr 29, 2009 | 03:01 AM
mustangman281
Banned
Ummm did you just make up a name for a part cause you didn't know the actual name? What are you talking about?
Old Apr 29, 2009 | 03:51 PM
grogan's Avatar
grogan
timing chain "cover" plate. my fault
Old Apr 29, 2009 | 05:04 PM
mustangman281
Banned
Are you talking about the front cover?
Old Apr 29, 2009 | 09:36 PM
grogan's Avatar
grogan
yea lol
tmdm
May 2, 2021 02:49 PM
ctgreddy
Sep 20, 2015 08:35 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
