hot side turbo kit?
hot side turbo kit?
You are bidding on a 96-04 Mustang GT 4.6 SOHC Turbo hotside kit and Masterpower T-70 Turbo w/ your choice of .68 or .96 a/r.
This kit does not require an aftermarket k-member, thats right it fits the stock k-member. Utilizes stock driverside exhaust manifold or aftermarket shorty header.
Buyers receive the following:
1 Hotside kit w/ Vband connections, T4 turbo flange, and 38/40mm Wastegate flange.
1 Partial 3" down pipe with Vband connections.
1 4" vband clamp
1 3" vband clamp
1 Turbo mounting bracket
1 crossover pipe exhaust clamp
1 Masterpower T70 w/ choice of a/r
Notes to buyer: Turbo comes w/ 1 year manufacturers warranty. Hotside kit comes with 1 year manufacturers warranty to cover the following only, cracking due to heat, non fitment not due to aftermarket suspensions or abnormal applications, and workmanship in fabrcation. this is the link 2 the pic of it.
http://cgi.ebay.com/ebaymotors/4-6-M...Q5fAccessories
ORRRRR
the mmr hot side turbo kit im also on a buget here if i got the mmr one i would have to get the turbo and a k-member and i got pi heads im planning on putting on. so should i get a thicker head gasket to lower the compression and what should my block be able to hold on horse power. i got a 97 mustang gt with 150k but no leaks and runs like a champ??? any one else know any other hot side turbo kits?? they have the mmr one some where in the fourms if you want to look
1 4" vband clamp
1 3" vband clamp
ORRRRR
There is Ponydown. Its a complete kit and its cheaper in the long run since that kit doesnt come with the cold side. Check it out. www.ponydown.net
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
