Engine RPM Differences
Old May 3, 2009 | 09:37 PM
grogan's Avatar
grogan
no..lol..its a raptor shift light..i basically use it for its launch feature..consistant 1700 rpm launch.
Old May 3, 2009 | 09:39 PM
grogan's Avatar
grogan
Originally Posted by mustangman281
Spinning a stock motor to 7K is just begging to have to buy a new engine. At 7K you are floating the valves cause the springs suck, scoring the cams and bearings due to lack of oil.
cant buy a new motor til this one blows...if it blows im getting a jpc 330ci aluminator
Old May 3, 2009 | 09:45 PM
ddmsgtr1's Avatar
ddmsgtr1
Was the car acting like it when you bought it or did you have it tuned? And if you had it tuned, what possessed you to set the rev limiter about 1200RPMs over stock?
Old May 3, 2009 | 11:06 PM
devongarver's Avatar
devongarver
ox, what is your rev limiter set at?
dimebag's Avatar
dimebag
retardedness?
Old May 3, 2009 | 11:19 PM
mustangman281's Avatar
mustangman281
Banned
My rev limit is set at 9000 so I don't risk hitting it since I rev to 7000.
Old May 4, 2009 | 12:25 AM
SVTeeshirt's Avatar
SVTeeshirt
which is very bad for your vehicle. Do not hit rev limiter!
Old May 4, 2009 | 09:40 AM
devongarver
ox, do you still have a build list for your motor floating around somewhere? i dont want to ask you to type it all out again, im just curious what you have put into that beast.
Old May 4, 2009 | 12:18 PM
mustangman281
Banned
Mod List
Engine
18cc manley pistons .020 over
Modmax 4340 H beam rods
Kellogg cobra crank
ARP main studs
ARP head studs
Felpro performance gaskets.
Stage 3 Patriot heads
CMS stage 3 blower cams
MMR cobra oil pump
Canton 7qt oil pan
TFS Trackheat intake
Solid motor mounts
Exhaust
Mac longtubes
Cam o/r H pipe
Slp loudmouth 2 catback
Poweradder
Paxton Novi 2000 race version
3in RR pulley
Innovators west 10% OD crank pulley
Ebay 4in intercooler
3in custom welded intercooler piping
ProM MAF
Mondo bypass valve
AIS meth system
Ignition
weaponX COP
3 step colder ngk plugs
Fuel
Custom sumped tank
A1000 fuel pump
100 micron filter
10 micron filter
-10 feed line (to Y block)
-8 feed line (from Y block to rails)
Aeromotive fuel rails
60lbs injectors
A1000 bypass regulator
-6 return line
Cooling
Meziere electric water pump
180* Tstat
Mishimoto aluminum radiator (fabricated to fit)
Brakes
Linelock
Gauges
Autometer C2 wideband
Autometer C2 fuel pressure
Autometer C2 oil pressure
Autometer C2 boost
A pillar triple pod
Steering column single pod
Front suspension
QA1 kmember
QA1 coilovers
QA1 adj struts
Steeda bump steer kit
Rear suspension
Megabite jr. lower control arms
Baseline suspension pro launch upper control arms
Baseline suspension antiroll bar
QA1 adj shocks
QA1 coilovers
CHE shock tower brace
Welded torque boxes
Rear end
33 spline moser axles
Spool
4.10 gears
C clip eliminators
Welded tubes
CHE axle brace
Wheels
17x9 black chrome 03 cobra (front)
17x10.5 black chrome 03 cobra (rear)
Exterior
01 cobra front bumper
Paint matched mirrors
03 cobra rear bumper
Drivetrain
Spec stage 1 clutch
Aluminum driveshaft
Old May 4, 2009 | 12:23 PM
devongarver
thanks!
