New Short Block
RE: New Short Block
i took a print out of the dss Supermod block i was looking at to the shop doing my work for their opinion. they called fps and they were able to build me a short block cheaper with dished pistons, and a cobra crank. after i ordered my block from him i saw another one of his blocks (not 4.6l 2v) on Horsepower tv (spike). but i'd say its at least worth a call.
RE: New Short Block
ORIGINAL: code3GT
VT, MPH or DSS.
VT, MPH or DSS.
these guys are the best, unless you know a closer shop to you that can build one, like in my case, Steen racing.
decide what you want to do, if your going for N/A, i'd say go stroker, and get some extra torque. a VT aluminum 324 has made 400 ft lbs in an N/A application. but it's a 6K shortblock. aluminum will save you weight but cost more. but an iron 302 stroker is probably your best bet.
RE: New Short Block
if your going boost than those guys block are no better than the one you have....I used them for parts when I'm in a pinch..I just buy the crank assly.....are you sure it's a rod or the piston slap that comes with the early 4.6's
Matt's 95 Stang
10-05-2015 07:16 AM
