ball joint problem
Old May 19, 2009 | 02:46 PM
steve r's Avatar
steve r
Default ball joint problem
Im getting this nasty squeaking noise when I turn my wheel or hit a bump..I had to replace a balljoint on my old 93 mustang and the same noises are happening on my 99 gt. the car only has 36,000 miles on it. Could the ball joint still be good just dry? or if its squeaking pretty bad it has to be changed? thanks for your help
Old May 20, 2009 | 02:52 PM
Sniper6677's Avatar
Sniper6677
change em out, they had non greasable designed bj's from the factory
Old May 20, 2009 | 03:24 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Well it sounds like you have dry socket... Is it a loud creeking kind of sound? Try to pinpoint if its the BJs or Tie rod ends. Poke a small hole in one joint at a time and spray some WD40 in there...see if the noise goes away. Do this to each BJ and tie rod (one at a time and retest) and you will find the problem. Does that make sense
Old May 20, 2009 | 08:17 PM
steve r's Avatar
steve r
I just changed out the outer tie rod and its all good, thank you
mtgldr
Feb 3, 2024 09:00 PM
guitarman376
Oct 11, 2015 01:47 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
trashxtrash
Sep 20, 2015 10:49 PM
ccdguy
Sep 19, 2015 05:20 PM
