Battery light turns on when I open it up?
Start simple and replace the belt with a good one like a gatorback or something. It's a cheap item that I am sure needs replacing anyways. I know mine does. While you are replacing it, it never hurts to pull the alternator off and have it tested free of charge when you go buy the belt!
Charge light coming on @ 5K
On my 97 Taurus, the same thing was happening, but gradually over a year or so, it got steadily worse and finally it was coming on at less than 3000 RPM. What I found was the field slip rings in the alternator were worn. I took the alternator armature to a alternator rebuild shop and they installed new slip rings for about $30. Problem solved. BTW, I also tried a new belt first.....no help.
Frank
Frank
Soldier GT
12
08-20-2015 09:42 AM
