Torque Converter Write Ups?
Old Jul 5, 2009 | 01:43 AM
MustangMan00's Avatar
MustangMan00
Default Torque Converter Write Ups?
Hey guys
Any info on installing a torque converter will be greatly appreciated, either your own experience or links to anything at all.
Thanks a lot.
Old Jul 5, 2009 | 02:20 AM
S197winstang's Avatar
S197winstang
I just started researching this topic as well. I posted a thread and got only a few responses. A bunch of vendors and the prices vary. The only negative thing I heard was that TCI had a bad rap from some. I am interested in this topic as well. Good luck.
Old Jul 5, 2009 | 03:45 AM
Xemeth's Avatar
Xemeth
Try and find a write up for replacing the clutch, it's basically the same.
The only differences is there should be a plate you can remove to gain access to the flywheel. You'll need to turn the flywheel with a screwdriver or something to gain access to each of the torque converter bolts/nuts (not sure what these cars use). Other than that it's the same as removing a manual tranny. Take off the mid pipe, driveshaft, starter, crossmember, then let the tranny hang down a bit and lean the motor back to access the top bolts on the bellhousing with a long *** extension and a swivel.
Just remember, a manual tranny most people can lift. It's heavy, but liftable. Automatics are ****ing heavy. Get a tranny jack or something. There's no way you and a buddy are lifting it, especially on your backs if you're doing it on jackstands.
Old Jul 5, 2009 | 01:28 PM
MustangMan00
yeah im trying to get a trans jack right now, and also i need to find a way of getting it high enough up in the air, because im lacking high lift jacks and jack stands....i have some but they only go about a foot or so :/
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
