Generic Electronic Module (GEM)
Old Jul 5, 2009 | 09:34 PM
88foxGT's Avatar
88foxGT
Default Generic Electronic Module (GEM)
OK I know the GEM is:
The Generic Electronic Module (GEM) is found on Ford vehicles and is basically a Body Control Computer. It controls many of the following functions on most Ford vehicles: Warning chimes and warning lamps, One-touch down driver’s side window, Daytime Running Lamps, Heated rear window, Windshield washers and wipers, Battery saver, Remote keyless entry, Illuminated entry with remote keyless entry, Interior lighting, Perimeter anti-theft and Four-wheel drive.
Has any one had any problems with these? 2004 Mustang GT the power door locks don't unlock on the drivers side with the switch or key fob. There appears to be power to the switch (per test light) and I also changed the door lock actuator. I've heard the possible solution to this is to replace the GEM. My question is where is the GEM located? If I switch it out, will it mess up any computer functions and where can I find these? Does the dealer have to install these for any reason? Thanks
Old Jul 6, 2009 | 08:53 AM
ChalknCover's Avatar
ChalknCover
Sgt. Killjoy
The only location diagrams I could find:
As to your other questions, I am not sure. The module may need programming since some electrical and computer components do, but I don't know.
Old Jul 6, 2009 | 09:50 AM
Eagle2000GT's Avatar
Eagle2000GT
In the drawings it looks like there are five separate generic electronic modules: 201a-e.
Old Jul 6, 2009 | 10:11 AM
ChalknCover
Sgt. Killjoy
I believe those are only the connectors going into the GEM. There is only one I think.
Old Jul 6, 2009 | 06:15 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
+1^ -- One GEM, five connectors...
Old Jul 7, 2009 | 07:44 AM
Eagle2000GT
When looking at the drawing I thought they went to different places. The box must have connectors on three sides. I tried google but couldn't find a picture.
Old Jul 7, 2009 | 09:47 AM
ChalknCover
Sgt. Killjoy
You probably won't find those pictures anywhere else. I had to go to alldata to get these. It looks like 2 are higher and 3 are lower on the module.
Old Jul 7, 2009 | 10:45 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Three on one side, two on another.
Here's the R&R from the '03 shop manual...
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
67LimeCoupe
Sep 21, 2015 06:34 PM
