you want mercon ATF for the 5 speed and it ends up being about 4 quarts you can take out of the pan. I have the automatic and the best method to re fill it was through the dipstick for the tranny but since yours is a manual, refilling it may be difficult, and you may not want to go with a synthetic fluid because you would be mixing it with a conventional which may cause it to gel...
good luck
