$1000
RE: $1000
gears (410 or 430)
forget the shifter...but if you must get a MGW
and then do some exhaust work, headers/midpipe/catback.
Then worry about induction, intake.
But for sure get gears and headers. 1000 will get the gears/ headers and install for one of them, but to install the other you'll have to hold off less you find an AMAZING deal.
RE: $1000
4.10> 3.27
They go in the big thing in between your two rear axles, lol.
remember on your old huffy bike, when you would switch gears the chain would go either to a bigger sprocket or a smaller sprocket? Same thing here. 4.10 gears rotate the axles more at 3000 rpm's than 3.27's do, therefore, you get faster acceleration.
Thats about the best I can explain it.
RE: $1000
ORIGINAL: DaMach04
Go with a UPR shifter!!!
ORIGINAL: BenScharf
I have a thousand bucks to spend on my 03 GT 5 spd, and I was wondering what you guys think. I for sure want the short throw. Any suggestions?
j/k. UPR is good, but I preferred MGW over it...but thats just me. Id get whatevers cheaper if i were u.
RE: $1000
go with some 4.10's, a short shifter, and steeda pulleys....then when you have the money i HIGHLY recommend you do a full exhaust swap (headers,mid-pipe, cat back), personally I think Bassani is the best way to go for exhaust.
