what should i listen for?
well ive been advancing my timing by 1 degree everyday w/my predator so far the car doesnt sound any different i dont know exactly what detonation or pinging soudns like what should i listen for ive tried putting it in fifth at about 30 going up a hill and everything sounded fine so i guess im good so far and or course im using premium
RE: what should i listen for?
Well the predator is only going to allow you to go 2 degrees over stock. So 12 degrees asvanced is all you're gonna get. Anyhoo... if you go past 14 degrees of timing then you will get a terrible surge when you hit the gas.
What you are listening for when you're looking for detonation is a rattling sound. Take a few small pebbles and put them in a coke can and have someone lightly shake the can from about five feet away and thats what detonation sounds like. You will mostly hear pinging in the top of the rpm band. Get on it hard and you should hear it. If you hear detonation at idle then something is WAY wrong.
Diablo Performance tune bumps timing to 20degrees advanced at idle, with a max of 22-23 degrees advanced at idle. stock timing is already 10degrees advanced.
ORIGINAL: jdaniel
Well the predator is only going to allow you to go 2 degrees over stock. So 12 degrees asvanced is all you're gonna get. Anyhoo... if you go past 14 degrees of timing then you will get a terrible surge when you hit the gas.....
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
09-17-2015 07:57 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
