Rear caliper retraction
i went out and got the special tool, i spin the caliper, but it wont retract. i have the cap off of the fluid resavoir, im spinning it clockwise. ive spun the thing like 20 times 0 movemement. as it sits i can barely fit the two new pads in the caliper, leaving NO room for the rotor. what am i doing wrong?
Thank you gentlemen. it is done. i had started with the needlenose, so my frustration had already built by the time i went to Advance and got thier house brand universal caliper tool (cube type) - it didnt fit and it had one flat side (no nipples). then i went to the locally owned store and they gave me another cube type with one extra side to it. by this time its almost 4 oclockon my only day off. so i reached out to yall. yup, wasnt pushing hard enough. i braced it against the strut and pushed whle i turned and sure enough, bada bing. thanks.
This is the one I have:
You put the adapter for the piston on one end, and the other has a 6 point for a ratchet. The shaft is threaded and a metal plate goes in front of the front part of the caliper so it makes the adapter push in as you turn the ratchet.
If you get the cheap Autozone brand ones, they usually don't work well. The one I have has never given me any trouble, unless it was a siezed caliper.
Matt's 95 Stang
10-05-2015 07:16 AM
maestro1024
09-21-2015 02:40 PM
09-16-2015 07:53 PM
